Thread: Reverse gp shift lever with oem footrest zx14r zzr1400 se
Created on: 01/18/21 10:27 PM
Martin2020
01/18/21 10:27 PM
Modifying for reverse gp shift while keeping oem footpegs. Are there any good options to the Healtech quickshifter?
* Last updated by: Martin2020 on 1/18/2021 @ 10:28 PM *
RE: Reverse gp shift lever with oem footrest zx14r zzr1400 se
01/19/21 6:33 PM
Do you mean alternatives to the Healtech? Knowing what I now know, I would go with the Healtech over the HM Plus. I might look real hard at the high end HM shifter but it's really expensive especially if you want to have clutchless downshifts.
How are you modifying the stock shift pedal to do GP shift pattern? You must be attaching a shift rod and using knuckle like aftermarket rearsets.
* Last updated by: Rook on 1/19/2021 @ 6:34 PM *
Martin2020
01/19/21 8:32 PM
Thanks yes not sure why the uploed pics arent shown
01/20/21 5:01 AM
NIFTY!
Nastynotch
Nastynotch's Gravatar
01/20/21 9:19 AM
That would take some getting used to right there.
2013 ZX-14R SE
2 Wheel dyno works flash
Muzzys black stainless slips
V1 custom mounted
Zero Gravity DB screen
Yoshimura fender eliminator
Black powder coated wheels
Martin2020
01/20/21 11:21 AM
Oem lever will be removed. Pics only show test fit
Martin2020
01/20/21 11:21 AM
01/20/21 11:21 AM
I think so.It's longer from the footpeg quite a bit.Maybe too long?I know when I tried moving my shift lever by a couple of splines,the trans didn't shift worth a damn.Even by one spline.At one point I bought an aftermarket rearset(s).To bring the pegs farther forward.
* Last updated by: Grn14 on 1/20/2021 @ 11:26 AM *
01/20/21 4:11 PM
I've moved the shift knuckle two maybe even three splines but it shifted the same. The shift pedal is still at about the same height but I moved the knuckle to take up some space in the length of the shift rod.
* Last updated by: Rook on 1/20/2021 @ 4:13 PM *
Martin2020
01/20/21 10:29 PM
I have modified several bikes to reverse shift pattern and theres generally no problems to turn the linkage a few splines. Will post more info once finished snd quickshifter fitted.
Martin2020
02/12/21 11:44 AM
02/13/21 10:29 AM
Thanks for showing pictures of that. We have a couple threads about converting to GP shift and what had been done in the past using aftermarket footrests is to position the shift knuckle so it points downward. They also had to space the footrest out a bit or reposition the spring on the side stand.
Martin2020
02/13/21 11:48 AM
Happy to help. Im used to reverse shift since racing superbikes. But want to keep original footpegs with rubber to avoid vibrations when touring. Will now fit quickshifter. Looking at the Healtech kit.
02/13/21 8:49 PM
I have an HM Plus. Looking at the the more intricate settings that are possible with the healtech, I think that would be my choice now. I really want a shifter with an autoblipper though. If I don't switch to an air shifter on my bike, I think I'd like an HM GP with autoblipper. Big bucks for that but damn, it's cool.
I have my shifter set on 90 mls. That seems about where the 14 likes to be set. I've tried 65 mls and it's not enough kill time. Maybe it would be better with GP shift pattern. I sort of think not and I'm apprehensive to try much lower than 90 mls again. 90's still very quick.
Martin2020
02/14/21 1:03 AM
Which aftermarket quickshifters have both up and downshift?
02/14/21 9:20 AM
I'm pretty sure Translogic does and the HM GP does but you need to purchase a blipper module. The HM ad I just saw said HM doesn't make a blipper module but I think they do. They have a product called the blipper shifter range.
Check out the video at the bottom of this page.
http://hmquickshifter.com/?post_type=product&p=8828&preview=true
Martin2020
02/14/21 11:21 AM
Thanks will check. So far throttle blipping up and down shifts has worked ok on my zx14r.
02/14/21 12:35 PM
Sure. I enjoy doing a blip for my downshifts and I've never had need to downshift fast four gear as rapidly as I could with a quickshifter. It would sure be cool to just nudge the pedal a couple times without bothering with the clutch or the throttle though. Actually, if I'm downshifting hard, I like to slip the clutch a little to avoid sliding or lightening up the rear wheel. The Gen2 might have a slipper clutch but my Gen1 doesn't. My busa which does have a slipper clutch doesn't intervene unless the back torque is extremely high.
JollyJBagel42
03/21/22 3:58 PM
I’ve been trying to look all over for a kit like this. Does anyone have a link or a brand for this shift kit while keeping the OEM foot pegs?
Martin2020
03/26/22 7:23 AM
https://pptuning.eu/set-for-revers-shifting-kawasaki-zx-10r-2016-c999?tree=171
Kit needs modification: Extend the shift rod or buy longer. Shorten the lever. Spacer between the lever and foot rest bolt.
Good luck
Persico
Persico's Gravatar
03/04/23 9:31 AM
Martin2020 where can I purchase your setup in the US. The link shows overseas only. Thank you!
2017 14R-Sold 2009 ZX14 SWB Strapped and lowered Alien head full exh PCV Brocks pump gas tune Schnitz flash Sprint race filter Healtech quickshifter Quarter mile 9.44 @ 150 Best 60 1.57 Best MPH 151.17 (No filter good air)
Persico
Persico's Gravatar
03/07/23 6:31 AM
If anyone else knows where this can be purchased in the US please let me know. Thanks again!
